RAKocher
- SE Pennsylvania
This nipple is NOT a dielectric nipple. It simply a plastic lined nipple.
It doesn't make sense, but that's what the manufacturer calls them.
If you want to connect rigid copper pipe directly to the water heater you need to use a section of brass between the steel and copper.
Although I do believe you're probably right and have the fix for this, it still doesn't explain how the cold water side can be completely unaffected or why the manufacturer doesn't require a non-copper fitting be used in their install instructions so they can tell people like me, "You did it wrong, and we can't help you!"
