If you read where I describe my 2 tank setup, where my electric tank is an emergency backup to a heat exchanger tank fed from a propane boiler, and how I normally just keep all valves open and let whichever tank is heating the water to heat both tanks. Well, now if the new electric tank is the one heating the water the impedance to reverse flow caused by that heat trap is enough to prevent the water in the other tank from being heated.
It’s not horrible, but it is disappointing that before if the propane boiler conked out I just had to turn on a breaker, but now I have to close a valve to isolate the cold water in the main tank and also have a greatly reduced amount of hot water until the boiler is repaired.
