Awesome info thank you. But that said, may I ask for your reference? Here's the definition that I found (reference link at the bottom) which is quite different from yours:
A*cryogenic liquid*is*defined*as a liquid*with a normal boiling point below –130°F (–90°C). The most commonly used industrial gases that are transported, handled, and stored in the*liquid*state at*cryogenic temperatures are argon, helium, hydrogen, nitrogen, and oxygen.
I will concede that N2O does not fall into this definition either. No problem. And you are correct about the boiling point.
So then the question becomes why do the articles I have read refer to it as a cryogenic liquid? (and in my case it is being stored in a tank with a coil and refrigerant in a liquid state to answer a previous post) Clearly, there is some kind of disconnect.
http://www.airproducts.com/~/media/...lBrkQFggnMAE&usg=AOvVaw2YYz2wNMZIull1oXxWky9f
I have no issue being incorrect. In fact, my ignorance is why I visit this forum. Unfortunately for you all...
Sent from my SM-G930V using Tapatalk
