ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
As I understand it, the critical pressure is the pressure required to keep the product liquid at the critical temperature. When the temperature goes above that, no amount of pressure will keep the product liquid and the volume will expand 440 times, causing catastrophic failure of the container.
Hmm... I'm skeptical. No amount of pressure? The pressure exerted by the substance when it reaches its critical temperature is infinite?
FWIW, I used to work for a specialty gas division of a major gas supplier. We had cylinders of nitrous oxide standing around on loading docks outside for days in the summertime and none of them ever blew up. They were standard (non vented) pressure cylinders, the same as the ones we kept O2, N2, H2, He, etc. in. Also, BTW, standard gas cylinders all have a burst disk type pressure relief valve that will vent the tank before the tank itself reaches its burst pressure.
