Re: NM-B cables through studs
Larry: i jumped when I should have zigged or zagged. I apologize for the application of my graphic to you, and i should have read your post slower. Mine was aimed at a whole procession of posters going back a couple of years. I am dragging the paper now. Who's going to come up with the graphic?
But i still think that for the most part, it is a moot code item, whether wood or steel studs, because for the requirement to have any impact, the wire has to be derated below it's normal usage. I do not have a 2005 to argue with, but I do not even know who is on the 2005. jurisdictions in California might go that way in 2006, but we are still waiting to adopt the 2002.
As a matter of reasoning, I do not see the difference of fire stopping a hole that has 3 14-2's, and the wires seem loose, and a hole with 2 12-2's that is tight.
I think that there ought to be a rule about craming wires tight in holes, but this rule doesn't work. I agree with sandsnow's point.
In looking at old nm wiring, overtightened connectors, overdriven staples, squeezed wires are where I have seen damage. I have seen bundled nm without problems over and over and over.
I think this rule is a poor attempt to fix an actual problem. I think it may be that the only way to actually get at this problem (wires pulled so tight in a hole that they can't be removed, or even moved ) is to write a an actual item about this. Remember we allow more than one 12-3 in connectors without derating, so it is not so easy. Giving power to the workmanship code might work, but then we will be giving discretion to inspectors, some who have no clue but the words them selves, no experience to compare.
But i do not see this current code as a fix for that hole so crammed, you could bet that the insulation is off some of the wires. That is where I have seen the evidence of fires starting, not 4 14-2's flopping loose in a 3/4" hole.
sorry for the animosity i created, still think the graphic is applicable to unaware mistake.
paul
