jjhoward
- Northern NJ
- Owner TJ Electric
I have seen NM cable fastened to wall studs with metal strapping. Did not get a good look, but I think it was not simply pipe strapping but NM cable strapping. It held about 4 pieces of cable, side by side with the metal strapping folded over the cable, then about 1 or 2 inches of the strapping was attached to the stud. Does anyone know if this is a manufactored product?
I need to fasten NM cable runs to the walls of basements w/out a running board. Did one install with regular pipe strapping folded over the NM cable and then shot into the block wall. (We will see what the AHJ thinks....)Is there an actual product to fasten NM cable walls?
Question 2: Since it could be argued that these basement walls are damp, must the NM cable be held away from the wall surface?
Thanks;
Thanks;
