glene77is
- Memphis, TN
QQ,
I think there are about 500 views on this thread!
You really started something ...
...the same thermal expansion as the conductor...
They are the only connector on the market right now that I know of that are al to al only rated. Tyco makes a crimp connector said:I have some grails in the shelf, also.
I like grails.
They remind me that life and work can be grait !
Have you seen the note that there are about 500 views on this thread!
You started quite a stir on this topic.
Speaking of which, I think this topic
will continue to stir itself
in the minds of a large number of open minded electricians.
I am not aware of problems reported with the new products, however the installed base is very small as the problems with the older aluminum drove all branch circuit aluminum out of the market place shorty after the new products came into the market place. I can only speak for the jobs that I worked on, but I did run the service van for about 10 years after the job and there were no more service calls on the aluminum job than on the copper jobs with the exception of one building where the roof was blown off and there was interior water damage. In that building there were some problems with connections at wire nuts where water had gotten into them.Don,
I am glad your experience worked well.
I am on the cautious side of Fire Safety.
I just want to show this viewpoint,
and read what others have experienced.
So, I am pleased to read your comments as well.
And Ideal has a letter from UL that says otherwise. UL does not permit self testing and neither do any of the other NRTLs. That is a big difference between here and Europe where the CE label is all based on self testing and certification.Aronstein has a memo from U.L. which states that the Purple was 'passed' on the manufacturers own testing, not tested in house at UL. That may be why there is only one size of Purple. His testing, and mine validate that the Purple is no more effective than any other hard shell wire nut under the same conditions.
IMO, both the Alum and the Installer are factors.
Alum is a reactive metal, oxidizes quickly.
Sweaty hands on the freshly stripped wires will excellerate the oxidation.
Comments?
In all of the years that I have been installing the stuff I can only remember seeing one or two out of hundreds actually install it correctly.
I remember houses were burning down left and right and they outlawed al wiring but it was never discussed with me I was just a kid.
You are asking me to go back almost 40 yrs for what I think I have proved my point and only with the help of the publication that you tried to ridicule me for stating. I dont remember where other than I know I learned this formally in 1984 in a film reel from the manufacturer. What exactly do you plan on doing with said references?? Dr Phil??Can you provide anything more then what you remember your perception was as a kid?
I am not asking anymore of you then I do of anyone else here, provide some references if you want to prove your point.
When and where was aluminum wiring outlawed?....it has never been prohibited by the NEC. The 15 and 20 amp sized aluminum conductors dropped out of the market in the late 70's as a result of the poor performance of the old style aluminum conductors. There is not a very large installed base of the new alloy with the CO/ALR devices as the product was not on the market that long. It was not a safety or performance issue with the new products, just the fact that there were significantly more problems with the old aluminum products than with copper products and very few understood the differences between the old and new products. As with all electrical installation the skill of the installer plays a big part in the performance of the installation and I believe that is even more true with aluminum than with copper, but that does not mean that the aluminum is not a safe product to use....
I remember houses were burning down left and right and they outlawed al wiring but it was never discussed with me I was just a kid. ...
In terms of experience, however, the only thing I remember was that
our shop (only 21 trucks then) never used Alum. The ole man 'Jim' said he used copper because he was a 'real good electrician'. He never really explained it.
It is just a way to pump ones own ego. (Something I am pretty familiar with.)
iWire,
I was reading and came across sometime interesting from Inspect-NY.com,
taken from their files from the Consumer Product Safety Commision,
.CPSC research shows that
homes wired with aluminum wire manufactured before 1972
are 55 times more likely to have one or more connections
reach "Fire Hazard Conditions"
than are homes wired with copper.
"Post 1972" aluminum wire is also a concern.
Introduction of the aluminum wire "alloys" in 1972 time frame
did not solve most of the connection failure problems
Always consider the source, Inspect NY has an axe to grind.
