That was my point: splitting the neutral for separate DC meters won't change anything relative to a single AC meter.ronaldrc said:As long as where dealing with resistance only and single phase or rise and fall happen same time across the windings DC or AC shouldn't matter.
Not even in your voltmeter?]Larry I don't have any in line ammeters.
ronaldrc said:If current does flow which I don't think it does,then we will have to go back rethink our theory on why the neutral conductor gets hot even when it shows no load with the standard clamp on ampere Meter.[/b]
winnie said:I think that I missed something.
Do you have a real situation where you have a neutral that is getting hot, but are measuring no current flow on it?
-Jon
Where have you ever seen this phenomenon? I believe it to be impossible, and that harmonic current would be read.ronaldrc said:If current does flow which I don't think it does,then we will have to go back rethink our theory on why the neutral conductor gets hot even when it shows no load with the standard clamp on ampere Meter.
ronaldrc said:Rattus
Threads are cheap
ronaldrc said:and they would try to call them feeders.![]()
I do! It's what carpenters drive through cables to create short circuits.ronaldrc said:Do you know what the term null in electricity means?![]()
ronaldrc said:Oh well now he knows
You know that last circuit I drew doesn't prove my point so I just give up!
