Re: No Good Options
busman: I never pulled a meter unless I was too uncomfortable, but I always ended up getting into more and more questionable situations, the more i did them.
for example I was putting new meter mains on units on a converted military base and there were no distribution disconnects, just the main transformer, run to vaults and distributed to old twin 30 zinsco disconnects on each house, usually mounted too high, so i had to cut pipe live, as well as remove and install new panel.
It wasn't too bad but the contractor I was working for wanted 2 a day. I could not quite do it without taking chances. Since there was no way for me to disconnect in an emergency, didn't even know how and which transformer ran which houses, I was unwilling to push it. I also didn't feel too comfortable leaving the job half done with those old slim blues taped to the wires and the wires unprotected overnight.
There was one day where he called and needed backup across the bay asap and i was pushed to get it safe. I slipped. That was the beginning of my change of heart.It ended up a standoff and we didn't work together again for a while.
I have also spent a lot of time futzing around with panels to try and make it safer without pulling meter. In many places by me, the meters are locked with wrap around locks and there isn't enough in bid for the down time waiting.
I have filled up slots with breakers. I have made cardboard chutes for the wire. I have gone back and forth more times than i can count with some panels. Sometimes I just ate it, rewired the panel as a freebie because i didn't feel comfortable with it, or with leaving it the way i found it.
But it gets old, and now there are cell phones to distract us. It's one thing for me to bite it when I chose to do so, but the idea that I would die because someone else is in a hurry is just not sane.
And I live in earthquake country.
it's your life and you should get to choose when and where to risk it, the vicissitudes of life notwithstanding.
paul
