romex jockey101
i was changing recepicals that were not gfi on a kitchen countertop to gfis.. the feed is bx cable and they used nm to feed the plugs down stream..the problem was that the previous installer used a plastic workbox instead of metal so i could not use a grounding screw as my gorund i had wrap a groung around the metal shething of the bx cable and spliced the nm egc together the gfi works and as well as the regular plugs down stream on the load side of the gfi...is this ok to do . if the previous installer didnt use a plastic box i could have grounded the gfi properly ...is this ok to do
