mbrooke
Batteries Included
- United States
- Technician
Then your saying you would put up with tripping 2 times a day? Sure you could move the dryer to stop it- but who wants to use the toaster in the living room or bath room?
Fist off houses are not wired for the individual they are wired for the general public.
Even custom homes are often sold within the first few years.
If you buy a new home (even a little cracker box) you can be sure there is a certain amount of power available for use in the kitchen area. 2 small appliance circuits.
Bedrooms are not required to be wired for hair dryer because the bathroom is.
Living space is not required to be wired for space heaters because these are not allowed as a primary heating source. Most homes either have central heat or at least baseboard heaters.
A bedroom is not required to be wired for a window AC unit. If it work it works, if not you are out of luck.
The reason for 2 small appliance circuits is there was the introduction of a lot of new kitchen appliances that had not been on the market before. Toaster ovens and microwaves, electric coffee pots and crock pots and a whole bunch of mixers and blenders and bread makers and whatever.
I still remember the coffee pot on the range and watching it perk.
Over the sink light everytime. No ties on MWBCs either.
Sent from my SM-N900P using Tapatalk
I am clear on what I am saying, the NEC is better when it does not get involved in design issues. You want to walk on both sides of the fence.
Because to be frank there are special cases where the NEC should incorporate a minute amount of design. The SABC IMO is and should be one of those cases. The NEC has had mandatory dedicated circuits for decades well before the bureaucratic take over- and there is indeed good reason for that. The rest I think both of us can see eye to eye.
And now we have floor recepts required in meeting rooms. Carry on.
40 years latter, sadlyBut Id argue its more from the agenda push products then intended design.
The completely ridiculous meeting rm rule cited by ActionDave is nothing more than a foray off into a place the code doesn't need to be- mandated overengineering at its finest.
Why #12? That sucks to work with.But to each his own, I respect that
You don't know your fellow humans very well I guess, some probably want to use the toaster or coffee maker in the shower.Then your saying you would put up with tripping 2 times a day? Sure you could move the dryer to stop it- but who wants to use the toaster in the living room or bath room?
Good design practice, but why does it need to be required? Later post mentioned tripping on cords - pendants from ceiling would avoid that situation, may not be as desirable but that is not what NEC is about.And now we have floor recepts required in meeting rooms. Carry on.
Yet there is inner displays in stores all the time that have extension cords running above drop ceilings to get to the display.For many years receptacles have been required for show windows . Some of them never get used.
What was the reason? To keep tenants from running extension cords above drop ceiling to window signs.
I have never complained about the requirement because we get paid to install them.
I don't know if there is a big need for floor receptacles but someone must think so. I would assume it's so people don't trip over extension cords or power cords.
We don't pay for this stuff so why should we complain?
That is what I typically do as well and why the rule sort of doesn't really matter to me anyway. I usually put all lighting on 15 amp circuits and nearly all receptacle outlets on 20 amp circuits.
Just what we did on new construction at the first place I worked for, and has mostly stuck with me. Not that I won't ever put receptacles on 15 amp circuits, but I usually don't.
I don't get how Fire Marshal works around here.That's why we have fire inspections by the Fire Marshal's office. Some areas are better at catching things like that.
If they do catch it they have the power to make sure it's changed.
You would thing a school would be a place where they would have an annual inspection or maybe even at least every 2 to 5 years have a general inspection and point out things that maybe have changed over the years.
