mbrooke
Batteries Included
- United States
- Technician
191003-0811 EDT
mbrooke:
Assuming ideal transformers, then the current at the input of the transformer is a replication of the output current, but scaled by the turns ratio.
If on the output side the wye mid point only has internal current flow, that is, no outward neutral current (all currents balance at the midpoint), then on the input side there will be no external midpoint current flow because of the scaled replication of the currents. Whatever balancing was necessary for this to occur took place on the secondary side.
In the real world this won't be true because of magnetizing current, and slight differences in the transformers.
But differences aside, there absolutely no load of combination of loads that can or will produce primary current? In other words its physically impossible? I'm trying to think a case that could or can produce current.
