76nemo
- Ogdensburg, NY
You mean the switch for the garbage disposal?
76nemo said:Okay, with the mind that tries to interpret theory, not code, what is the reasoning to have the diswasher on a switched leg? On a three-wire system, the fault is protected. Why the concern of the door/safety latch not being a reasonable mean for disconnecting the cycle?
have noticed that also. I don't think many disco's can stand up to the abuse and corrosive nature of salt. It also may have to do with flooding during hurricanes.Mountaineer said:In Virginia, we have never had to put the DW on a switch. When I visited Nag's Head I noticed that the electricians do not have to put a disconnect on the load side of the meter base even if the service cable feed was ran through the home three stories up to the panel.
I am in Virginia and in my area plug and cord is fine. Basically, it boils down to the local inspector vesus a state thing. If the AHJ knows how to do proper interpretation code.....then it makes it easier.Mountaineer said:In Virginia, we have never had to put the DW on a switch. When I visited Nag's Head I noticed that the electricians do not have to put a disconnect on the load side of the meter base even if the service cable feed was ran through the home three stories up to the panel.
Dennis Alwon said:I was trying to convey that a disco was needed but a breaker lock would also work. I did not get into the if's of the breaker lock. Thanks for clarifying. I may have misled them there.
I always have a disco either under the adjacent sink cabinet not on the wall. It would be just my luck to be working on the dw and the ho flips the switch while I am lying on the floor.
zog said:Charlotte area
I dont think it looks bad at all, I think 99% of people would never notice, the other 1% are in this forum![]()
