Just remember: There are 10 types of people in the world..... those who understand binary, and those who don't.![]()
Would these be "decimal" people?
Heinz R.
Why is the "quad" arrangement preferred over the more usual 2 double-pole breakers? Is it cheaper to do it this way?
Heinhz R.
Now thats not confusing. Take a look at this prize. I bought a large quantity of breakers 17+ years ago and got a case of these factory mistakes.
"Space" and "smaller" do suggest similar goals.I don't buy the space is a premium situation in a moblie or manufactured home.
The tandems and quads will fit more poles in a smaller overall lighter assembly.
Wayne quad breakers with both the inner and outer poles having common trip are readily available.While these breakers are very common in manufactured homes, the reason they are not that pricey is because they are not common trip breakers, they only have handle ties for disconnecting purpose, a common trip breaker would be imposable for the outer two breakers. I had to replace one and was surprised the cost wasn't as bad as I was expecting.
Of course as was said, the trailer manufactures buy them at truck load prices so for them there even lower, but they are used as space in a manufactured home is a premium so as was posted is correct.
If you ever need any, look for a trailer parts supply house, they keep them stocked in all sizes, great when you need to add an AC unit to the inside panel if the outside disconnect don't have a space for it. you can get them it about any configuration, I have used ones with a 15 amp on one side and a 20 amp on the other with a double 30 amp in the middle.
I have seen trailers with all tandems and or quads even with half of the panel empty.
Look at the right column on page 79 here:
http://www.eaton.com/ecm/idcplg?IdcService=GET_FILE&dID=353658
Look at the bottom of the page here:
http://cmsapps.sea.siemens.com/controls/speedfax07/07Speedfax_pdfs/07Speedfax_01/01_25.pdf
"Space" and "smaller" do suggest similar goals.![]()
Did you note the photo in the (second?) post where Westinghouse specifically notes them as Common Trip? While I agree with you that it seems unlikely, it appears they got them listed that way.While these breakers are very common in manufactured homes, the reason they are not that pricey is because they are not common trip breakers, they only have handle ties for disconnecting purpose, a common trip breaker would be imposable for the outer two breakers.
My childhood home had them when air conditioning was added to a panel; I don't RECALL any problems, but I left it in the late 60's.
