ruxton.stanislaw Spammer
Suspended Member
- Arkansas
- Laboratory Engineer
We are looking for a 100 kW inverter or array of inverters that will output a nominal voltage of 440Y/254 V 50 Hz. While on-grid inverters support that voltage range, with the hardware being capable of it, the software needs to tell the hardware to operate at that specific voltage off-grid Typically, the inverters have either 240 or 277 available as the configurable off-grid or EPS voltage. I am looking for a recommendation as to an inverter that has a more specifically configurable voltage, so that we can avoid buck boost transformers.
