goskime
- Bangor, Maine
I friend of mine asked if I would hookup their kitchen light. It had come down while he was fixing the pull chain switch. He didn't want to put it back up because it had some old looking wires in it.
When I looked at it, it was typically old house wiring. The fixture bracket screwed onto the wood and two black wires hanging there. The wires were two separate conductors. They were originally a solid wire. Maybe a tap off some old knob and tube wiring, to which someone had spliced a stranded wire on to make the connection to the light. The house is said to be over a hundred years old. My first thought was to put a box there. But the unspliced wires were right up near where they were coming through the ceiling,under that we had strapping and a tin ceiling, the wires were not long enough to get into a box. I insulated the wires as best as I could. The hot wire had a bare spot about 1/2 inch long. Made sure that everything was well insulated and put the ceiling light back up. I told the homeowner that there was no box under the light. But short of tearing the ceiling up, I figured that at least it was better that what I found.
Is there a better way to handle this type of problem. When I have encountered these problems in the past there was usually a reasonable way to get a box on the outlet. Other points of view?
