Not to sound snarky but if its an existing installation built to the code in effect at the time does the NEC (or any adopted code) require a performance test when service work happens like replacing a feeder, breaker or pump?None of that addresses the neutral to earth voltage that the bonding is designed to control.
Is there a NETA or IEC standard for performing such a test?
