kwired
Electron manager
- NE Nebraska
- EC
I don't evem know what that means
So under the 2005 NEC before I was required to tie the handle ties to gather i run potential multi wire circuit to two rec. in a two gang box I close the breaker for line one but I leave the breaker for line to open. My garbage disposal is tied to line one but I don?t own a dishwasher. So I have a 20 amp 120 volt circuit. After working on my disposal I plug it into the rec. that is feed from line two this breaker is in the open position , so my disposal doesn?t work. Am I plug in to a branch circuit or not.
Line one meets the definition of a branch circuit with the breaker in the closed position
Line two meets the definition of a branch circuit with the breaker in the open position
Neither one of these circuits meets the definition of a multiwite branch circuit until I close both line one and line two breakers.
Line one and line two are two 20 amp branch circuits working independent of each other
Even now you can still have one line with breaker closed and other line with breaker tripped and a handle tie between them and still have mostly the same thing you described and it is still called a MWBC.
Requiring the handle ties did not change what is a MWBC, it changed how a MWBC is to be disconnected from the supply voltage.
