jumper
- 3 Hr 2 Min from Winged Horses
There are no numbers for this up or down, either way is fine.The crowd that says: either or, is fine in my book.
I have no problem with this.
You know the saying....that being said we all have them.No code reference to quote and everybody has an opinion.:smile:
another poster with common sense! Kudos to you byourdesky!So after reading Karl H's theory of why the hole up is the best way to do it and everyone that is of the thinking that hole down is just fine.......not one of you has ever seen an old run of conduit with the hole on the bottom pull off the wall :-? I know i have and i've only been at this for 4 years....never seen a hole up install falling off the wall though![]()
another poster with common sense! Kudos to you byourdesky!![]()
well for starters, it helps to be able to spell......I really want to have common sence, but I just can't bring myself to do it wrong.
well for starters, it helps to be able to spell......![]()
it was dead at least 10 pages ago.
I can simply assert common sense and all is well. Heavy weight applied to pipe with strap on bottom bends strap. Same heavy weight applied to same pipe with strap topside and strap doesn't bend. No problem. Are you suggesting that I can't do advanced math? Again I assert that I don't need to for this. Let's not complicate it with fuzzy math ok?It also helps to be able to do advanced math if one is asserting a a position regarding this question. Is it opinion or fact that you base your assertions on?
The phyicist did not say it was untestable; he said it was unanswerable as presented. Diifferent conditions would apply at different times and that the engineers who tested for these conditions were probably correct and that the fact that the NEC does not address his issue would imply that it is TOTALLY IRREVALANT. The straps are rated for installation in either position, so IWIRE is correct! It is solely a matter of opinion regarding the position. If you want to argue this further, bring on your numbers! I miss physics and calculus, so I would gladly spar numbers.
"A heart . . . "ah if I only had a brain.
