mbrooke
Batteries Included
- United States
- Technician
This is the situation why we can't add a third grounding wire to service entrance:
My parent house is part of a 5 house compound (called townhouses). The utility service entrance is outside the red gate. There are 2 houses between the utility and my parent house which is at the back. Our feeder is under the driveway. We need to demolish the driveway just to access the feeder and wires. Distance to front is 35 meters.
This is our service entrance panels outside the compound in the street:
You can see the feeder is small. And it is about 35-40 meters to the house main panel crossing many bends under the driveway. If we pull it out. We can no longer put a new 3 wire inside because the feeder is corroded and rusty (they put the wires at every angle during construction before driveway was concreted).So the only sound solution is 100A RCD (30mA) just to protect the Siemens subpanel. All the appliances in the homes will be protected by GFCIs. Hence pls. give me the most advanced RCD model in the planet, perhaps one you can even monitor with smartphone
So how do you propose we replace 40 meters of new wires under the driveway (or even adding just the ground wire)? The neighbors won't allow. They don't want any power interruption or not able to use the driveway during the repair or destroying it (the new concrete won't blend with old one). They don't use any ground wire just like millions and since nothing happens to them. They thought it was superfluous. And lastly, they don't want my parent 40 meters wires and new feeder to hang on their driveway.
No conduit?
