Michael15956
- NE Ohio
You have pleaded your case several times - no one that has responded has bought into the idea that a fitting becomes part of the raceway even a cemented on PVC fitting.
Fittings become a necessary component of raceway systems but are not raceways themselves, and in the case of RMC, and IMC a termination fitting is not necessarily required you can simply thread the raceway itself to provide a means of termination.
Is a hub a fitting? Yes in the case of a myers hub. Is the hubs of a one piece device box a fitting? No - if anything the entire box is the fitting and not just the threaded opening.
Kwired, I'll respond to this post simply because you have address the debated issues.
Even if I redact my statement ref. a fitting become part of a raceway, a fitting is allow in the said section, you even agree with that.
Now, with a fitting, PVC can be treaded wenchtight, no one has disagree with that and that is another point no one has responded to.
Most importantly, there has been a blanket statement that PVC cannot support a box and again no one has put forth a section to support that statement. They only spin off and argue over a fitting but that IMO is a weak argument for such a blanket statement.
