Outdoor "under cabinet" lights
conmgt
2 Phase Philly
Hello,
I need to install down lights on a soffit. The soffit is very shallow and 3.5" wide. That won't allow a recessed light so I'm looking for low profile surface mount lights suitable for a damp location.
Any thoughts?
Line voltage only. Otherwise I'd have to run the LV wire through a wall to the power source and I believe that's a no-no.
kwired
Electron manager
NE Nebraska
Hello,
Any thoughts?
I'd bet you have several LED options out there. LV wire run through wall depends on some specifics of what you select, some will work some will not.
cowboyjwc
Simi Valley, CA
All of the 7-11's here retrofitted their exterior lights with a single tube LED fixture. I don't know the brand, but I'm sure it would work.
