Even if you disregard any whimp factors, productivity normally isn't all that great in those conditions.
This is true, but we have a builder that wants stuff done yesterday
“ shoot low boys their riding shetland ponies”
we do a lot of Habitat houses and there can be several "volunteers".
nothing worse than a homeowner mad about an outlet 1/4” off with a tile backsplash. Grout lines will definitely show it.
.....for countertops, I chalked a line and set them all the same height.
I don't own a rotary laser but I think his point was to do something to ensure they are same "level" and that is what I ordinarily will do for countertop outlets as well.I only use a hammer / stick in new construction. Remodels get the rotary laser.
If you base a chalkline based on an unlevel floor, you'll have unlevel boxes above the counter. A good trim carpenter will shim the cabinets to make the c'top perfect, and you'll end up with unlevel devices on a perfect tile backsplash.
I've never seen a plastic box for residential with a center line to go by if you place/measure to the center of a box. You could figure out one then cut a gauge stick for the rest.Residential 16" , commercial 18" to center.
Ruler or jig for height and depth.
Space to code plus whatever floats mine or the customers boat.
Where it matters I use a level.
Kwired got itHe said he chalk lines at the same height. If the floor's out-of-level then the chalk line's out-of-level.
You are correct, not too many out there but some how I figured out how to do it.I've never seen a plastic box for residential with a center line to go by if you place/measure to the center of a box. You could figure out one then cut a gauge stick for the rest.
In a kitchen, the best bet is to have the tile installer identify a top or bottom mark, and then level from that mark.
Tell the GC you will not be responsible for outlet placement without that input.I've never seen a tile setter on the job when I'm there roughing in.
Wow. I gotta fix everything.(j/k)
Okay, then leave wire and cut in old-work boxes later on.
