misterbill1972
- Cali
I have a motor that is 6900 Volt, 7500HP. Is there something besides the over 600V section of NEC ?
Does it use a soft start or VFD?
If this motor is having issues I would do exactly what I said above. What exactly is the question? This motor is not even NEMA rated. That rating stops at 500 Hp. So, it will not be consistant with other motors. Non NEMA motors are exempt from standard NEMA ratings in regard to HP, Speed, Frame, Voltage and so on. It is a beast of it's own.
It has a soft start. The reason for my question is how do you get something inspected if you cant find in NEC ?
