stickboy1375
- Litchfield, CT
charlie said:Dennis, I don't care if a light switch corrodes a little or if a bit of moisture gets into a light. However, I do care if an overcurrent device doesn't operate. Considering the open nature of a molded case circuit breaker, I don't want any moisture in there.
As far as the outside overcurrent devices in NEMA 3R enclosures, they are listed for the purpose. With that said and from a personal standpoint, I don't like outside installations of overcurrent devices. There are situations that require installations in NEMA 3R enclosures and the panel is OK with that. I can't speak for the rest of the panel but that is the way I feel about the situation.![]()
Last I checked, I use the same breakers in a 3R panel as the ones in a non 3R panel, so not sure I understand your post.
I guess I just dont know why a bathroom has moisture but outside does not?
