jrudyk
- Austin, TX
What is the minimum clearance from the ground/floor to the panel?
jrudyk said:What is the minimum clearance from the ground/floor to the panel?
jrudyk said:I went to a 68 house today and had to check the service panel an my knees.
That just doesn't seem right.
The last bad receptacle I replaced, I had to get on my knees! Thats not right! A little old lady had to help me up!:smile:jrudyk said:I went to a 68 house today and had to check the service panel an my knees.
ItsHot said:The last bad receptacle I replaced, I had to get on my knees! Thats not right! A little old lady had to help me up!:smile:
Sure:smile: it is! You get to lay down on these!stickboy1375 said:I install a lot of them in the baseboard, I have to lie down to install them, thats not right!
JohnJ0906 said:I helped with a 24 unit retirement home once. Each unit was to be ADA compliant, so we put all the panels at 48" to the top. I cut them all in while sitting on a bucket. Nice.![]()
jetlag said:The only code Ive been able to find is 24'' above ground for a mobile home outside disconnect. But guess what I called the AHJ on a situation in an old house where I needed to install a 200 a panel and all I had was 18" above floor, He turned me down . I had to cut 6" out of a 4x12 beam to get 24" . I know its not in the code but around here you dont aegue with the ahj, They will nic pic your jobs to death if you do.
ultramegabob said:I dont believe panel height is an issue, its a maxium main breaker handle height issue, if you have a main breaker that is....
ultramegabob said:I have never heard of that as a requirement before, that is just goofy![]()
If you don't stand up to them, who will?jetlag said:I know its not in the code but around here you dont aegue with the ahj, They will nic pic your jobs to death if you do.
