- Licensed Electrician
They are the same thing, there is no difference between a ground bar and a neutral bar. It's a piece of steel with holes drilled in it.
I believe there are listed neutral bars that can also be used for equipment ground.
My feeling likely wrong is that the typical ground bar is not meant to carry continuous current.
Can a wire nut tell if it's being used for a hot, neutral, or equipment ground?
I just don't think they have a pile of neutral bars in one bin at the factory and then they have another pile, the same size and colour, made of the same material that are for equipment grounding only.
