WarrMann
- Atlanta, GA
Only if that lighting does not have a heavy duty lamp holder. If it has a heavy duty lamp holder, than you can put a 60 watt load on a 40 amp breaker if you use the right size wire.For a 9kva site pole loads 480V three phase can the breaker be 40 amps? 210.20 would it not say 40 amp over sized?
Sent from my SM-G935U using Tapatalk
You really need to look at the thread on the first code section you asked about.
You keep re-asking your question without acknowledging the advice you've been given
Sent from my SM-G950U using Tapatalk
