Pesky Power Line
If they can find a bit longer board they might eliminate the pesky problem altogether.
Have seen where pipe liners put caution ribbon on the primary neutral to keep equipment out of it. Somebody either new a little about distribution or really risky....
I'm calling BS on this photo. At that voltage that 2X4 will be conductive.
But there is more than just that one 2x4 between that conductor and "ground" lot of other wood frame in the path, if this were only a 2.4 kV distribution system it might be even more possible - until maybe when it rains. Still risky to attempt though.
How could they miss that at the planning stage ?
Maybe they didn't, but POCO hasn't done something they already agreed to do?
POCO I work around the most wouldn't have open MV lines that close to a structure, and has moved older lines over the past several years because of potential liability reasons
I can't tell you how many youtube videos I have seen of people moving tall loads or excavators or other tall equipment where they have propped the electric lines up with wooden supports. Sometimes there are people holding the supports off the ground as the vehicle comes through.
