- Windsor, CO NEC: 2023
- Hospital Master Electrician
No, I think it would be more correct to say that for a line-to-neutral load, then the neutral is the 0V "x" axis of the graph.hardworkingstiff said:If you used A and Neutral for a 120-volt circuit, would you say they were 180 out?
But 180? could be verified a different way: At any given instant, the "A" phase will be exactly opposite "B". For example, when "A" is on the upswing of the cycle (say at 45V), then "B" will be on the downswing of it's cycle, at -45V. Without a neutral reference, then it would look like one wave (not seperate A & B waves) that measure 240V at their peak.hardworkingstiff said:If you use A & B for a 240-volt circuit, I don't think it is correct to say they are 180 out. (They appear 180 out when referenced to the mid-point, aka neutral).
But then, does a change to the reference change the nature of the waves? Does standing on phase A change the nature of the pair's interaction? No, it just changes the perspective. If you're standing on phase "A", and watching phase "B" from your vantage point, without any other references your mind would perceive that you're standing still, and "B" is moving 240V away from you.
Whether both phases are oscillating between 120V+ and 120V- at opposite times, or one phase is oscillating between 240V+ and 240V- depends entirely on your frame of reference.
If you'll excuse me, I'm going to go make a tin foil hat now. :lol:
I agree, I mis-spoke. I'm going to mull this over some more.Lou said:I have to disagree with you. The phasing perspective is all about reference to ground (neutral).
