masterinbama
- Huntsville Alabama
AKA half-size, half-inch, tandem or wafer breakers.
I have the tool that slots the pan for this type of breaker.
The slots were like box knockouts, prepunched but still installed. The tool made knocking out the punched slot easier, although most people used 'needle nose' pliers.Why would you need such a tool? If the panel is not designed for tandem breakers you should not be installing them. If you have an old non-CTL panel the instructions will state where tandem breakers can be used and you can purchase non-CTL tandems.
Ok, that makes sense. I thought the tool was being used to punch slots in non slotted spaces.The slots were like box knockouts, prepunched but still installed. The tool made knocking out the punched slot easier, although most people used 'needle nose' pliers.
