Mister Kool
Is wire pulled in pipe (conduit) safer than romex????
If so, then why is romex allowed in our homes but not our offices ?
Mister Kool said:Is wire pulled in pipe (conduit) safer than romex????
If so, then why is romex allowed in our homes but not our offices ?![]()
infinity said:it is for all intents and purposes banned in commercial construction.
augie47 said:In commercial (office) work, one other aspect to consider is the ease with which a circuit can be added or altered with a conduit system. A spare, or underfilled conduit can make adding a circuit far from the panelboard a breeze compared with having to run a new NM circuit.
RHaggie said:Loose EMT couplings and connectors will arc when a ground fault occurs and this could kindle a fire anywhere along the conduit run.
kid_stevens said:NM is pretty well resticted in the 2005 NEC Article 334 for construction types 3-4 & 5.
I have seen many fires caused by overloaded NM.
In New Mexico only dwellings, Multi Family Dwellings and structures 3 or less stories in height can have NM installed.
kid_stevens said:NM with its complicated stapling and routing requirements can not even be removed and replaced easily while the wall is intact.
Mister Kool said:that arc shouldnt kindle a fire cause the breaker should trip
iwire said:I think a better question is why our homes can be made of combustible materials and are not required to have sprinkler systems.
RHaggie said:Safety was the original question, not future considerations. Adding a circuit to a conduit system IS easier if there is enough cross-sectional area left to not derate the capcity of every conductor in the conduit. I have seen many installations where not only were the conductors NOT derated, they were fully loaded and the conduits filled close to capacity. Then again, they may have been OK at construction and it was after the final that the monkeying around took place. That's the point. What is easier is often disquised as simply being lazy. Pulling a wire in an existing conduit has potential ramifiactions down the line that can change the original design to sub-standard.
Which brings us back to safety, doesn't it?
Conduit systems are easier to improperly alter later, making them less safe than originally constructed. NM systems altered after the construction have the better chance of being installed as originally constructed...generally speaking.
stickboy1375 said:Depends entirely if your good or not... lets see you add a wall sconce with conduit after the walls are closed up...
kid_stevens said:Hey cowboyjwc where is here? I want to live there.
