charlietuna
110.4 Voltages. Throughout this code, the voltage considered shall be that at which the circuit operates. The voltage rating of electrical equipment shall not be less than the "nominal" voltage of a circuit which it is connected.
I consider the word "NOMINAL" in 110.4 to mean in engineering terms:
"Real versus nominal value in engineering - a value that is used as the name for an actual value which is close but not exactly the same."
Now, taking your approach, let me ask you how many 115 volt rated appliances have you installed on 120 volt sources which actually operate at or near 130 volts? "SHALL NOT BE LESS THAN "NOMINAL VOLTAGE"". I had a code instructor years ago that always preached " knowing the code is important, but knowing why it is code is more important". His name was Mike Holt.
