jeremysterling
- Austin, TX
But this way you are giving the circuit two more additional points of future failure.
Truly, the points of failure exists at the sharp end of the deck screws!
That is a pretty bold assertion.
If they are done poorly, then yes. Done properly, no problem at all. <<<I agree 100%
But why give yourself (2) possible failure points if you can avoid it?
Would you Home Run every outlet? Run multiple switch legs?
Do not notch beams, joists, rafters. The strength in a joist is in the top and bottom 1 inch of material. Compression on the top, extension on the bottom. Think of a steel "I" beam. The strength is in the top and bottom steel. Boring holes in the center is much better. Splice boxes and re-routing is a good idea. Also, storage boards typically only need a few screws in them so they do not move around. This is not a habitable floor, I hope.
If you have an 11' span with 2x6 joists then you have a problem. If the ceiling joist is part of a truss then I am not sure they should be drilled. What depth insulation do you have in the attic. Around here you need R-30 so that is 9-10" of insulation. I would fur the joists with 2x4 and then notch where the wires run. I would then get more insulation and then screw down the plywood.
As a couple have at least partly covered, just what exactly is the joist to be bored, notched, etc. If it is part of a truss it is possible it should not be bored or cut at all as that may effect the strength of the entire truss. They can make a large framing member out of pretty light material but about every bit of the material making up the truss is critical to its performance.
I realize you are over a 5 ft wide hallway, but is the joist in question part of a much larger truss? If so that truss is depending on the integrity of all the components making it up for its strength. Drilling the bottom chord may not hurt it as far as vertical stresses since it is a short span to hallway walls that will help support it, but very well may weaken it for horizontal stress imposed on it. The weight of the roof will be placing some horizontal force on the bottom chord.Thanks everyone for the replies.
the offending wire is located above a hallway that is 5 ft wide running diagonally about 10 ft.
i removed some items left by the previous owner and found wiring with decking layed on top of the wires !
i removed the decking and inspected the wiring. no apparant damage.
i have since removed that decking and sawed the decking to free the wire, no notches or boring. the wire is out in the open and exposed for all to see.
i am still working on the problem with the hall way. the wiring is #14 for a 3 way light.
if i bored a hole it was going to be 3/4"
no notches or boring was to be done over the rooms.
thanks again,
james
after reading all of this, i'd be considering storing my metal boxes downstairs in my closet and hanging my shirts and jeans off of the rafters in the attic.![]()
thanks again,
james
I just don't see any reason to avoid j-boxes other than the time it takes to mount it and make up the splices. If the pay off is worth more than the effort, and we agree that good junctions don't fail; where is the downside?But why give yourself (2) possible failure points if you can avoid it?
Hi all,
in our new home, the electricians drlled holed in the middle of the 2x6 ceiling joists which is ok i know.
trouble is, most of the wiring is ran on top of the ceiling joists, wiring pulled tight.
james
Great graphic, Dennis. Notice trusses are not part of it? I believe the OP's situation is in violation of code with holes bored into trusses.Here is a good reference
Dennis, I think your reply is pointing the OP in the wrong direction.
