Why arent the mounting holes threaded in most of the 4/0 and some of the 1g Plastic Boxes ?
One less step the manufacturer has to take thus making the boxes even cheaper. Just a guess.
That's my problem with them. The Standard 6/32 or 8/32 screws you would generally use (if too long)
will usually bind up an come to a stop.
Just use drywall screws then.That's my problem with them. The Standard 6/32 or 8/32 screws you would generally use (if too long)
That's not likely to stop me.That will no longer be allowed in the 2014 NEC.
Sheetrock screws dont look too classy in the fixture canopy of a 4/0 plastic box though.
Me neither, shhh............
Spend a week working with me and your opinion will be even lower.Good to see professionals here :ashamed:
Its not so much the screw itself but the surface area of whatever it is screwing into that makes the
difference. That's the difference between mounting the box something and mounting something to the box.
