at least you had the nerve to admit to it!
I never understood the issue with it. They are pointy so they find the hole easier and the coarse threads = less work to tighten the screw.:wink:
active1 said:All we use or ever see here is EMT and metal boxes.
Some villages require min. steel 4x4x1.5" unless there is framing in the way.
active1 said:Done.
Never noticed it was missing.
stevenj76 said:I prefer a steel mudring in front of the ufer.
Why are they plastic,
stevenj76 said:I like to run a 3/4" smurf tube up to the attic and down to the crawl from the panel for future.
Maybe if you work in a trailer park you might see a plastic box here.
Why are they plastic, does it make the trailer home lighter and faster?
Or is it a fuel econimy thing?
We don't care much about the weight when the building is bolted down.
jrclen said:Why not plastic? Do the metal boxes help hold the house down in a tornado or what?
active1 said:Ya, but only if you pipe em.
