POE for a camera
caribconsult
Añasco, Puerto Rico
Retired computer consultant
which one is best in low budget?
POE is def less expensive....a pair of adapters with a throughput of around 500mbps can be had on Ebay for under $50, even less if you can get by with less speed. I have 3 older Dlink units that probably have around 85mbps, perhaps less on my actual system, and they are sufficient to connect a 2nd wireless access point and our Envoy PV monitor device for our solar system. They can be had for as little as $10 or so. Just keep the distance limitation in mind.
hillbilly1
North Georgia mountains
Owner/electrical contractor
I have ran cat V ethernet over 900' sucessfully, but I have not tried POE that distance. I had a WAP at the end of it that was powered at that end. As others have said, try a 500' box.
That's good to know. I have a solar inverter 650 feet away that I want to get data from . I was going to just try it and see if it works. I am sure the data rate it sends is very low.
GoldDigger
Placerville, CA, USA
Retired PV System Designer
If it is actually using Ethernet as the encoding standard over the wire, then just carrying a low application data rate will not allow the Ethernet connection to be usable over a longer distance.
If the twisted pairs are being used for a different transmission protocol, then the Ethernet distance limitations will not apply.
Note that despite its name, you can use Power Over Ethernet on a CAT cable regardless of the actual communication protocol, as long as the appropriate provisions are still made for power injection and extraction.
