Cow
- Eastern Oregon
- Electrician
We usually wing it and err on the side of overkill. An extra foot or two really doesn't add that much concrete, but we're not usually doing 40 at once either.:grin:
It was 18 feet not 18 inches. Easy to miss that!
The highest pole we allow here is 25' measured from grade. Most are 14' and we still have about 4' in the ground and 2' above and they have to be engineered.
I hope you are talking about poles for parking lighting, and other similar lighting. 25 feet is not going to get the job done on some industrial sites or at a ball field, public roadway lighting is most often higher than that also.
25' max for industrial sites, if you need more light add more poles, the height of the poles depends on the location here, close to residential it is only 14' or if close to the street. Don't do public roadway lighting, and the only ballfields that are lit here are the parks softball fields. I believe that they are 60' feet (could be 40') with 12' bases.
Our city ordinance allows 0 ft/c past the property line.
No public roads?Don't do public roadway lighting
I can understand most locations having the 25 foot limit, but industrial can have so many possibilities for height required to illuminate anything.
You have no signs/billboards that are 25 feet or more in height?
No public roads?
