FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
If we install a panel remote from the dwelling wouldn't we have to install ground rods for the panel? It is a separate structure, IMO so rods or ges would be required
what about a "spa" panel that has one 240v 50A gfci ocpd and also serves as the pool gear disco, which is out 50ft from the main panel and it just gets mounted to a block wall, where such panel is 15ft away from the pool gear. the sub is not technically in any remote structure. the sub enclosure itself would be tied to EGC. you need a rod for this?
