Coppersmith
- Tampa, FL, USA
- Electrical Contractor
My son-in-law would like to use a portable generator to power his house in case of outage. Three questions:
1) The neutral from the generator will not be switched. (Backfed breaker with interlock on main). Is there any danger if the generator neutral is connected while using utility power?
2) Should he tie the generator frame to the same ground rod as the service?
3) The generator inlet will be about 40 feet from the backfed breaker in the panel. Does there need to be a breaker closer to the generator inlet to protect the cable like there would be for a service entrance cable?
