K8MHZ
- Electrician
I am certainly suprised with all the responces that I have received regarding this issue. Sounds like this is not the only one out there that might be doing this. Our radios work at the 800 range and scan multiple ranges and channels. 16 channels each bank with 4 banks of channels. Motorola XTS 5000R to be exact. I am going to have him change out radios for a week and see if problem continues. I am also going out to his house today with my radio to see if same issue can be duplicated. Because my after work hobby is to serve as Assistant Fire Chief, the radio being the problem does have me concerned so thanks for pointing out those issues. I will try to update after trying some of these suggestions.
I went to Motorola's site and checked out the radio. I did not see any mention of FCC Part 90 certification, although I would not think Motorola would skimp out on that.
I also noticed the radios had a feature that enabled emergency communication without pushing the PTT button. Perhaps the radio is transmitting in emergency mode somehow??
Are you sure the radio is not a counterfeit? Motorola has warned their customers that fake public service two way radios are now coming out of Nigeria.
Someone mentioned periodic tone bursts. I didn't see that on the specs, and we don't use them here. Our public service radios are all Motorola. Tone bursts only happen on un-key.
Let us know what you find out. My hobby is radio, with a particular interest in emergency communications. I have friends that are firefighters and work on radios and if there is a Motorola issue, I know they would like to hear of it.
ON EDIT, maybe OT: Are your radios compliant with the new narrow band standard that went into effect in January? I see that the nomenclature for the radios indicate some may not be set for the new standard.
