Positive or Negative Alternation of the sine wave developed across the load.
In one half of the AC cycle current flows through the diode and the voltage drop is all (or mostly all) across the resistor; in the other half current does not flow though the diode and all the voltage drop is across the diode. What's so mysterious about that?
170628-2011 EDT
lbmcse:
I am glad you are hanging in.
I suggest that you not worry about the internal working of a diode, whether a semiconductor or tube type. Ideally it is simply a switch that is closed when the applied voltage polarity across the diode is in one orientation. and open with the opposite polarity.
Don't try to analyze a circuit's operation by what particles or charges you think are moving in the circuit. Just accept the convention that in an external circuit (not the source of energy) that positive current flow (whatever it may be) flows from a more positive point to a more negative point.
In any circuit the sum of the voltages around any closed loop is zero.
In any circuit the sum of all the currents at a point (a node) is zero.
In the simple circuits you are looking at you have only one series loop. Thus, at any point in the loop at an instant of time the current is the same, and in the same direction at any point.
At an instant of time the voltage drop across the load is equal in magnitude to the voltage drop across the voltage source, but one has a polarity that has opposite the other such that when you add voltage drops going around the loop in the same direction the sum is zero.
I second GoldDigger's comment.
I'll put the diode before the resistor, scope it; then place it after the resistor and do the same.
It actually doesn't matter in this circuit, which side of the resistor you place the diode, as long as your output voltage probes are connected across the resistor.. What matters is the orientation of its terminals. Whether the bar side points CCW or CW with the circuit, as this will determine which direction of current it will block.
Look at a diode symbol. It looks like an arrow pointing direction in which a conventional current will always flow in a diode. Remember it and it could help solve the problem you posed in OP more easily.
