As with my patience.Famous photo by Dorthea Lange entitled "No End in Sight"
I'm not sure what else you could add, but you keep suprising me with more examples. Very nice ones, I might add.I understand that it isn't your field and I'm still willing to elucidate and educate in any way that can help your understanding.
Hi mivey,I'm not sure what else you could add, but you keep suprising me with more examples. Very nice ones, I might add.
Thank you kindly, sir.I'm not sure what else you could add, but you keep suprising me with more examples. Very nice ones, I might add.
I think mivey might have been referring to my real world examples taken from my own personal experience of those actual cases.Hi mivey,
You appreciated Besoeker.But you did not tell even a single word of appreciation to me for my efforts, as self-assumed manager of this thread,in moving the thread in a specific direction.I feel let down.
Well, thank you. That gave me a good laugh - nearly fell off my chair!Now coming back to your remark
''I'm not sure what else you could add,''
I want to say Besoeker as an expert has concealed some important information so as not to concede his defeat.
Wrong again. What I gave are the motor characteristics. They are what they are regardless of method of control.I hereby expose that secret information to you.
The torque-speed characteristic of the induction motor displayed in the diagram of post#170 is based on what is called open loop control of induction motor.
It isn't a method of speed control. It's just the motor characteristics. They are what they are.In that method,motor speed control
So are you now conceding that your comment from post #151:is feasible within a very narrow range
is incorrect?the speed ...changes appreciably.
Yes there is.But there is another method called phase controlled induction motor drive with feedback control by which the induction motor can be run at any speed below its synchronous speed by reducing the supply voltage alone.
Single phase, no speed feedback. No credibility.A block diagram of phase control drive is shown below.
http://www.st.com/internet/com/end_application/375.jsp
It reduces the voltage just the same was a conventional light dimmer. To paraphrase the cooking shows......here's one I made earlier..A simple phase-control switch is used to vary speed by changing the motor torque.
is incorrect?
A variable frequency inverter.
But hang on a minute....
Isn't this the very technique about which you commented thus about speed control?
Good....it was intended as an attempt at humour. British and I wasn't sure that it would travel well.I do not know why but that really did make me laugh out loud.![]()
I hope I made you aware of your need to learn more.It seems to me that these lines from Hamlet are appropriate to your position in this discussion:
I already gave you a real life example at post#151.Do you have any similar of your own to share with us?
Oh!You knew nothing of it?!.Sorry for assuming you were an expert!Well, thank you. That gave me a good laugh - nearly fell off my chair!
Wrong again. The motor characteristic are determined by the design and construction. They are what they are. The method of control, or none, does not alter them one whit.Modification motor characteristics are one of the fundamental rules of control theory in achieving speed variation over a wide range of induction motors.
With a standard induction motor you can't. If you don't believe me, try it.My comment is based on phase control drive with feedback loop method of induction motors in which variation of motor speed down to zero is achievable.I based my request for you to learn more on that.
That completely misses the point. The power side shows a triac.See the black arrow pointing from the motor to the control unit.It represents the feedback loop. Feedback of what though? It isn't the normal way of showing speed feedback.
A conventional light dimmer is no match for it,
No it isn't.because the same type of controller with additional circuit for slip recovery scheme (to feed the rotor power back to source to improve efficiency) is used in motors of MW range in water pumping stations
It can't. If such a technique was viable it would have long ago eclipsed the need for variable frequency inverters. Actually, if it were the case, they need never have been developed in the first place. But they were. Think about that.Please make a study of phase control drive and you will realize that speed of the induction can be controlled over a wide range with that control method by reduction of applied voltage,
My post #170 gave motor characteristics. Just that. They are what they are. Nothing there precludes operation in variable speed mode with a suitable variable voltage and variable frequency source. Varying the voltage alone just doesn't cut the mustard.unlike your post #170.
You still don't get it. My motor and the characteristics I presented have nothing whatsoever to do with the means of control. Nothing at all.In fact, which water pump installation will need your pump motor control with almost fixed speed?
This is not relevant.I asserted that the speed of an induction motor can greatly change with change in applied voltage.You challenged that it can not be done,because an induction motor is a constant speed machine.I showed above that it can be done.Whether it can be done with an ordinary induction motor or a special induction motor is irrelevant.Both are induction motors.With a standard induction motor you can't. If you don't believe me, try it.
I only said a light dimmer is no match for a phase control drive with its additional circuitry such as feed back control circuit etc.,I did not say they did not have any thing in common.That completely misses the point. The power side shows a triac.
You misunderstood me.Please read again my first entry in this post.The method of control is by phase control to give voltage reduction which is exactly what a dimmer does. And the very method you said "is feasible within a very narrow range".
This is unfair on your part.You did not mention problems which baffle you and which are not yet solved by you.Then only your question of ' Now,what did you want me to learn?' is relevant.It's the real deal.
An upgrade replacing all the control gear and starters whilst retaining the main motors.
The original kit was around the early 1950s and there was little technical data on the original design and what little there was didn't match nameplate data,
I spent an inordinate amount of time trying to reconcile various disparate data to come up with designs to match the requirements.
From the end customers perspective, it was a several million ?UK project between the pump refurbishment, new pipework, and our electrical content.
Huge pressure on me to get the electrical design right despite the distinct lack of data.
Something like that seriously tests your understanding on electrical machine theory.
Whilst it gave me a few worries and some sleepless nights we got it right.
A change in the operational point is not a change in the motor characteristics.I do not know how to convince you with 40 years of experience in the field.However,I'll try a bit.Surely,the motor characteristic are determined by the design and construction but not invariable.The change in applied voltage changes the torque-speed characteristic of the motor as is clear from your own post #170.
And here was I was beginning to think I might have to send you a bigger shovel...I don't.A very simple auto transformer motor speed controller changing the voltage and hence the motor characteristics is given below.
You also said within a very narrow speed range. Ho hum....This is not relevant.I asserted that the speed of an induction motor can greatly change with change in applied voltage.
Again you seem to miss the fundamental point. Both are voltage control. And you had already correctly accepted that speed control by voltage variation was a very narrow range.I only said a light dimmer is no match for a phase control drive with its additional circuitry such as feed back control circuit etc.,I did not say they did not have any thing in common.
within a very narrow rangeYou misunderstood me.Please read again my first entry in this post.
Que?This is unfair on your part.You did not mention problems which baffle you and which are not yet solved by you.
The R2' takes care of that. It's the transformed R2/s where s is the slip.Bes, shouldn't your motor equivalent circuit have a load resistor?
May God bless,'Long live, Besoeker!'.I'm an old fellow. I might even make it to my next birthday.
Well, thank you kindly, young fellow.May God bless,'Long live, Besoeker!'.
Take a good look at those curves. Can you see the obvious problem? I'll let you ponder that for a bit. With your superior knowledge of machine theory and clarity of mind, I have confidence that you will get there.
The instability problem exists exactly because the voltage is reduced and the motor is operating on the wrong side of the speed torque curve. Reducing the voltage further will not fix that.You are talking about the operation of motor in statically unstable region of the motor characteristic.This problem does not exist,when the voltage is sufficiently reduced for speed control.
What you showed in post #193 actually demonstrates the problem quite well.Yes.That is for open loop control.With feed back control and circuitry to limit stator current,the closed loop control can vary the motor over a broad range.In case of variable torque loads such as pump motor,open loop control is found sufficient (up to a range of motor size), as I already showed in post #193.
