Not an experiment. An investigation.As you said,'similar experiment.
See posts #17, #20, #22, #25may be yours also suffered from the same limitations.Is it possible for you to reproduce what you did here?
What more do you wish me to add?
Besoeker;1353733. See posts #17 said:Please give your numerical results as gar did in his post #1.
So crunch some numbers and show the net savings.Please see
http://www.samwha.com/fc/tech/tech4.pdf
See also post# 91 where fault level of 22 kv or less is mentioned for residential service 120v/240v.
If the fault level is 22 k,there is practically no reduction in voltage drop due to connection of capacitor of size say,3 kvar . But if the fault level is less say 4 kva (This is not unreasonable considering power supplies in developing countries),there can be considerable reduction in voltage drop.
Interesting comment. You call me an expert yet don't believe what I'm telling you?
And this that you submitted purports to:
Yet it tells you otherwise.
I straightened it out a wee bit and enhanced the contrast. I hope you don't mind.
Why not try that to convince yourself ?Of what, I wonder...
As it happens, one of my erstwhile colleagues, who ought to have known better, tried voltage control of induction motors on a test fixture for a client. He used thyristors (called SCRs elsewhere) in an inverse parallel configuration - a W3C arrangement.
It didn't work.
It couldn't.
It doesn't.
I did. See post #5.Please give your numerical results as gar did in his post #1.
You might have tried to.That is why mainly I and Besoeker tried to analyze the performance of induction motor first.
Thank you, zbang.Or, more accurately, a failure to understand scientific method. In the usual progression, someone presents their thesis, data, experiment information, and conclusion. IMHO, Gar (and Besoeker) have done this. .
This from your post #266.
I don't know where you were going with it.
T.M.Haja Sahib, I think if you were witnessing the Wright Brothers' (inventors of the airplane) first flight in an airplane you would argue with them that their invention couldn't possibly fly and their numbers were all wrong! And as now, you couldn't show them anything done on you own. I think it is time to concede and move on.
:rotflmao:T.M.Haja Sahib, I think if you were witnessing the Wright Brothers' (inventors of the airplane) first flight in an airplane you would argue with them that their invention couldn't possibly fly and their numbers were all wrong!
Hoist applications utilizing the principle of reducing supply voltage for speed control of induction motor make mockery of your prohibition,sir.Please seeIt didn't work.
It couldn't.
It doesn't.
Hoist applications utilizing the principle of reducing supply voltage for speed control of induction motor make mockery of your prohibition,sir. Please see
http://www.jpsdesign.com/Portfolios/Hubbell/InstructionManual.pdf
Yes.Because I am also an expert
I thought that you had already got there in post#199Please reveal it.It may also help the original author also.
You realise that this is for a wound rotor machine with an external rotor resistor, don't you?Hoist applications utilizing the principle of reducing supply voltage for speed control of induction motor make mockery of your prohibition,sir.Please see
Obfuscation?At what?
