Thanks, Bob.Smart $ said:...email me the higher res' image and I'll see what I can do with it...
Wouldn't X "improve" pf?rattus said:The phasor diagram is fundamentally correct, but the value of X appears to be about twice that of R. X should be much less than R in the real world.
Line impedance negligible? Impedence combines resistive, reactive, and inductive components. Perhaps you meant line reactance? If "line impedance in the real world would be negligible" is truly valid, that would make this whole discussion moot, not to mention VD calculations for any circuit.kingpb said:The drawing you are using, or one similar is also produced in Elements of Power System Analysis, and it specifically states that the magnitude of IR and IX are exaggerated in order to illustrate the point more clearly. The actual effect of the offset due to line impedance in the real world would be negligible.
Please reread what I wrote. It does not say the line impedance is negligible, I stated that the offset is negligible.Smart $ said:Line impedance negligible? Impedence combines resistive, reactive, and inductive components. Perhaps you meant line reactance? If "line impedance in the real world would be negligible" is truly valid, that would make this whole discussion moot, not to mention VD calculations for any circuit.
Actually it doesn't matter whether you were stating offset due to line impedance being negligible, or the line impedance itself negligible. The result is the same... The statement is not concise enough to elicit distinction. Yes, I have reread it... Yes, I mistook the subject of your statement. Only through implicit remark am I discerning your intent. Nevertheless, you did not specify what offset. You could have been referring to voltage offset, rather a pf-theta offset, or both. Suffice it to say, it was unclear to mekingpb said:Please reread what I wrote. It does not say the line impedance is negligible, I stated that the offset is negligible.
BTW: Thanks for reminding me that impedance is made up of resistance and reactance. I guess I didn't remember that without "X" you don't have a power factor, which means you don't have an offset, which means the offset would be negligible.
Spend a little more time reading, and a little less time trying to be so Smart!![]()
