Back to this. Supply power generally comes from a power transformer. DC in that would be unusual. Saturated transformers and all that.Offset in the sense the mean is not zero?
Are you (also?) saying there cannot be a DC component to an AC-supply-power waveform?
It's a power waveform. If the is no direct current in the power transfer, there can be no DC offset in the power waveform. It is simply a shifted or offset waveform... no DC offset.
It's not DC.0<PF<1
some offset, ie some real power and some reactive power
As shown, there is an AC component in the DC at six times supply frequency but the supply side of the bridge doesn't see a mixture of AC and DC.
yep
it represents the positive power flow
it is why the Parks dq transformation is useful
negates the cancelling ac component and leaves the dc
makes the math much simpler
Total signal = DC + sin(wt + ph ang)
yes it is
DC + cos2wt
and it is 'offset' lol
How though?
assume
pf = 1
all pu quantities
single phase
v = sinwt
i = sinwt
w = 2 Pi f
Power = v x i = sinwt x sinwt = sinwt^2 = 1/2(1- cos2wt)
simple trig identity
you now have a power signal:
Whose frequency is 2 x f
whose phase is shifted by 90 deg from v and i (sin vs cos)
whose AC component magnitude is 1/2 of either v or i (1/2cos2wt bs 1sinwt)
And who has a DC component offset of 1/2
No DC...it has a DC component
v = sinwt, note no dc
i = sinwt, note no dc
assume pf=1
v x i = sinwt^2 = 1/2 (1 - cos2wt), note now there is dc
the 1/2 x 1 is a DC offset component
Net consumed power average. What most consumers get billed for.Would this not be RMS power instead of DC?
No DC...
Yes, the sinusoidal waveform is offset (i.e. the mean value is not zero), but it is not "DC offset".
I think we can agree it has a constant component and a sinusoidal component. Apparently many find it objectionable to refer the the constant component of a power waveform as a DC component, since it is not a current waveform, and the current waveform in question has no DC component.the waveform has an ac and dc component
Only for a sinusoidal waveform with no constant component.RMS is waveform peak/(sqrr2)
Cheers, Wayne
Yes, it has a constant component, the disagreement is in terminology, should that constant component be called a "DC" component, when it arises strictly from AC? I would just call it a constant component.but power, the product of v and i does
