Open Neutral
- Inside the Beltway
- Engineer
I could use of those flywheels. I have a dinky 6A generator that won't run my fridge or my furnace blower; it drops to 90V/45Hz when trying to start either.....
An interesting question. It is not likely that you will increased the fuel burn or reduce the vibration but you could consider capturing the heat.An important question is how to greatly increase this efficiency?
I realize that, and because of what you mention is reason why it can withstand a short duration surge of current like you might encounter with starting a motor. But the prime mover needs to be able to respond to this surge or it will stall. I may be somewhat incorrect, but I would guess the engine is most efficient somewhere near full load rating of the driven generator.121101-1057 EDT
kwired:
Full load rating of a generator (alternator) is a thermally determined value. This rating is for a continuous load that will not cause the maximum hot spot temperature in the generator to exceed some absolute value, like 120 C, while the generator ambient is at some defined value. If the generator is some higher ambient, then the power rating has to be derated.
The generator maximum power capability will likely be much greater than the thermal rating. External control circuitry could make the two power values the same. There might be some generator designs that could cause limitation of peak power capability.
As a very rough estimate maximum power output to the load occurs when the load impedance equals the source impedance. In a DC system it is fairly easy to see and measure the characteristics. For high efficiency a generator is designed with a low source impedance compared to the load impedance. Thus, peak power capability for a generator will be much greater than its continuous rating.
A diesel engine has higher thermal efficiency due to the higher compression ratio.
I don't know why there aren't more small generators (5-10 kW) with diesel engines. I wanted to use one recently for a small sewage pump installation but I couldn't find one. I wanted diesel because of my own experience with poor fuel stability of gasoline.
Must be limited in your area. Here are some: http://www.generatorjoe.net/subcat.asp?0=541
Availability may be limited due to higher cost also.
I went to the site and now have questions.....
They list 3600 rpm engine speed. For a diesel? Good luck!
Also, electric/recoil start. Again, for a diesel?
Wiki diesel and check out the max rpm for even a turbocharged diesel with electronic controls.
121031-0930 EDT
I should have used less than than 30 kWh on the generator yesterday and fuel consumption was about about 6 gallons of gasoline. Gasoline is worth about 33 kWh per gallon. Thus, overall efficiency was less than 16%. An important question is how to greatly increase this efficiency?
121102-1117 EDT
cutting engine size down to that which is sufficient for average electrical requirements rather than peak can have a big energy impact.
The big issue with propane is can you get refilled when you need it?
I guess that may depend on where you are at and how much propane is used in your area. Where I am at, propane delivery trucks are about as common as diesel delivery trucks, and most are operated by same fuel companies as the diesel anyway. Most of farm fuel tanks anymore have monitoring devices on them, that automatically orders more fuel when it is needed.The big issue with propane is can you get refilled when you need it?
