- Windsor, CO NEC: 2023
- Hospital Master Electrician
Re: Pre Hire Test
Well, I guess that renders me unemployable at a commercial or service shop!
			Do I get a second interview?My answers (w/out codebook) to the quiz originally posted by Rich R:
1. (C) 3
2. I can oblige you there...
3.(B) 15
4.(B) GFI Protected
5.(D) 18
6. Copper? Not a clue.
7.(B)Reverse any 2 wires
8. Not a clue. I'd check photoeye, and go from there...?
9.(B) 10
10. (B) Main panel/interior breaker panel
(If "main panel" includes the service)
That hurts.Santacruzer's:
To bend a 10" offset using 45 degree bends on 1 1/4" EMT, how far apart do you put your marks on the conduit?
Not a clue.
What is the voltage on 480 Delta? (phase to phase and phase to ground)
Not a clue.
It seems to me that logically, 480/277 is a wye style voltage, so I would bluff on the test and state that the voltage to ground is "240". However, I've never heard a soul speak about a 240/480 system, so I'd probably assume someone (you or me) goofed, and scribble that out and write "277."
What color is the ungrounded conductor? Gray, Green, White or Pink.
Pink.
If you can't answer these questions off the top of your head, you have no business being on a service truck.
Nuts.Marc's:
I generally have them bend some 3/4 emt over an obstruction and draw a start-stop circuit. That sorts em out enough for me.
