There are some restrictions in 210.21
Have you ever tried to find a NEMA 40A receptacle for a range that calls for a minimum 40A circuit and breaker?
Tapatalk!
If you overload a circuit you overload a circuit, what difference does it make what kind of plug is on the end of it?OK. Doesn't sound right being able to do this, but, OK. Is what it is.
Thank you !
Tapatalk!
The fact is a 30A recpt protected by a 20A breaker is safe. That is all there is to say about it.ok ok
Just thinking it didn't sound right.
20 amp brk, 20 amp wire, 30 amp recept.
Not only putting a possible heavier load into that receptacle, which may trip if someone thinks theres a 30 amp circ..
Are you willing to be satisfied once you put a stop to this one particular, possible thing an untrained person could do? There will be more you have not seen or thought of yet. Start down this road and there is no end other than a journey into madness.but also, we project or suspect people to do things, which brings this circuit closer to someone saying "just" put a 30 amp breaker on it. It will be ok.
Just saying.
ok ok
Just saying.
"just put a 30 amp breaker on it" doesn't quite work out though if you have 15 or 20 amp cord caps and want to use a 30 amp receptacle. 15 amp straight blade caps typically will plug into a 20 amp straight blade receptacle, but I am not aware of any 20 amp configuration that will plug into any 30 amp receptacle.
I could see where installing a larger receptacle on a smaller sized circuit could also be took as violating 210.23 because it allows a load larger then what 210.23 allows?
I do know that putting a 20 amp receptacle on a 15 amp circuit in an area where appliances that have a 20 amp plug on its cord is a big mistake as home owners will try to use them to the full load current and you will get call backs from tripping breakers, a garage is one such area because of air compressors and small welders, I just don't like installing things that I know will be abused and cause call backs, and of course Joe handyman will fix it by just installing a bigger breaker even though the conductors are only rated for 15 amps, just not a good combination
