I am an electrician for over twenty years. I hold Master's Licenses in two Counties. I have wired residential and light commercial for my entire career.
I just purchased a new construction home in a different county that I work in (Dutchess County, NY). Here there is no license requirement, and there are a choice of companies that electricians can use to inspect their work.
My new home has: A microwave oven outlet, that is not on it's own circuit, so every time it's powered up the kitchen lights go dim. This is the built in style that mounts above the range.
I opened a box to install a dimmer and I noticed that instead of making splices and adding pigtails, they just landed the extra wires on the screws. So on one switch, I had one wire stuck in the back (fine here) and then two jammed under the screw!
I then went and opened every high box in the house and they are all the same. Same story on switched outlets.
In the master bedroom I have a switch that controls nothing. I can't find a switched outlet. They also failed to give me three way in my dining room, so I can only control the lights from one single pole at one entrance.
In the panel I have the neutral and equipment ground for each circuit landed under one screw.
Additionally, in the other bedrooms the switch controls the outlet closest to the door, a location I can literally reach from the doorway. Not a violation but an example of poor quality work.
So far he has demonstrated a poor working knowledge of the NEC and he failed to test everything in the house.
Any caveats or recommendations before I call this guy back here and then write a letter to the AHJ and the BBB? I would prefer to have this guy fix everything on his dime, rather than going the latter route.
